A couple of days ago I noticed some slight bulging on the sidewalls of one of the Coopers, and on closer inspection I found slight bulging on three out of five. It isn't very noticeable, but if you run your hand around the tyre you will feel it straight away. I took it straight into Tyre Power, the local Cooper dealer, who inspected them and said it was normal. He said that they have a band in the carcass where there is a join of some sort and that a slight bulge can often occur. Does this seem like a legitimate explanation and are these tyres still safe?
A mechanic mate says hell no. I have just inspected my BFG KM2's and there is nothing of the sort on them.
Any advice?
Tomorrow i'll be dropping some of the hard-earned on a set of 285/75R16 ST-Maxx and steel rims to replace the worn out 265/70's currently on the GU. From everything i've seen they should be fine with the standard 2" lift and a good upgrade on the current rubber. Hopefully its all fitted for my trip in a couple of weeks.
Jason.
