oh ok so im on the right track then, thanks for your help mate. seeya around hopefully.
I have rhe clip you need but would be taking it out of a complete caliper which is probably no big deal ro be honest. Going the twins will be best mate.
No master upgrade. Direct bolt. Winner.
yep caliper, caliper bracket, disc and backing plate is all you need and it will all bolt straight on
Brake booster is unchanged. You will need the new calipers, pads and rotors. Make sure you get the bolts for the calipers because they are longer.
I actually bought mine through the marketplace on this forum about 3 years ago. I saw a set for sale on Facebook in nsw today I'll see if I can find it for you.
These calipers were only found on TB42 efi Patrols.
Thanks Winnie, I am not on facebook so if you do find I hope here is a phone number. What sort of cost?
yer its a little scoop for cooling, the cut out for the caliper is larger as well
Has no relevance to me .............. but this is a good thread.
