Tis' the way of this world it seems these days unfortunately. Trades and proper trade practices have gone out the window and people just don't give a f$#k anymore. Get the job done and as quick as possible and onto the next job.
The concern with CRD is that the fuel rail pressure / fuel pump can see high pressure >160MPa (23000-25000psi) @ full load. As you cannot compress water, this condition can strip minute particles of metal off the pump plungers (damage) and stuff injectors.
You can take a sample of the contaminated fuel (store some anyway for latter reference) and place it in a small glass tube (say 10mm dia x 30mm depth) and shine a UV pen light light up thru the water column from underneath and if metal particles are present you will see them as bright glitter. Hopefully you caught it early.
I had CRD fuel pump failure couple of years ago and as a precautionary measure installed a WaterWatch pre filter (supplied by Responsive Engineering -Cooma Diesel). Something to consider as well. Give Responsive Engineering/Cooma Diesel 02 62800178 a call _ just more info / knowledge for you to deal with these cowboys.
https://www.waterindiesel.com.au/
Insist on a injector return leakage test be performed and a fuel system check by a diesel injector SME workshop. The owe U that at least.
The tanks were repaired about 2 or 3 weeks ago, and it’s only done around 220km or so since then with no issues. The day before the warning light came on, I’d pumped about 10 or 15 litres from the Aux to the main to ensure the transfer pump was working, so I am suspecting the aux tank was the culprit. Once the warning light came on it was a couple of kms to home, no misfiring or problems at all. So hopefully no further problems.
I’ll be having a chat to them tomorrow about my concerns for the longevity of the injection components. I’ve already pulled the trigger on the Fuel manager system c/w alarm. I looked at the water watch system but preferred to go with a unit that filters as well.
I’ve got no hope of mounting the fuel manager where you have yours, as the later CRD’s with rear air have different routing of the air con line. I’ll need to run it from the passenger side, which isn’t ideal.
Yes Dave is the man ! Cooma Diesel . work is way above the average . You get what you pay for
Went to one of his trade training nights_Think he was the first Denso rep in Aust
I have done his machine work for about the last 20 years ..
Yesterday.... Kallen got me banned from faceache for another 3 days after my 24hr banning!!!!!! *LMAO*
