They are Mint!!! :)
Yes there is. I ran this offset top kingpin bearing on the passenger side of my GUIV for many years and it sorted out tyre scrub, drift and wobble for a long time. I rate rhis mod.
http://safetsteer.com.au/portal/content/view/192/338/
check the adjustment of the wheel bearings .. My ute with 50mm lift is mostly stock ..
BFG tyres . air bags on the Back .. tighten up the wheel bearings . A bit tighter and was a bit worried . But it fixed it .. So .
Harmonic’s, much like bridge collapse’s occur, poor or lied to maintenance of all parts millimeter accentuating IMHO [emoji120][emoji120]
MR MB here kindly nailed it. Even a micro disturbance can send the whole lot out of rhythm, and harmony is broken.
Mine is perfect now across the whole speed range (knock on my empty nogging it stays so) . I chased my wobble gremlin for months with a heavy machine gun shooting $$$ bullets at it...
During that time it used to drive like a dream at all speeds. Then i'll drive over a tiny bump, even those reflective doodahs on the freeways, and then whole thing will start dancing and won't go away until i was at very low speeds.
In the end new bearings fixed mine, but only temporary. After that it was the draglink and panhard bushes and been good ever since.
