Hi guys,
The A/C (and heater) fan is not working on the first three levels, but goes to full on level 4.
Any ideas? My thinking is that the motor is on it's way out and requires full voltage to start spinning?
Hi guys,
If it is a GQ, the resistor pack which is inserted into the air ducting will be shot. The resistor pack is positioned just under the glovebox, next to the fan housing. Either that or the switch is jiggered.
Wot mudnut said X 2
99.9% the Ballast Resistors have had the richard.
yep,mine did the same in gu..resistor
And another one here... Resistor pack underneath dead. Happened one my 2009 GU as well.
Under normal circumstances, #4 setting there is no resistance. Straight through Volts.
1, 2 and 3 are resisted to slow the fan down. Over time the pack becomes dry on the inside and becomes brittle. Some have had success with solder and bits from Jaycar. But for the cost of a new pack, it's not worth it.
Thanks guys, I shall check the resistor pack.
Mine's has similar issue. Number 1 is not working but 2,3.... ok. I haven't bothered to replace the resistor yet 'cos I rarely use the number 1 speed. :)
I managed to solder a bridge into the fusible link location on the resistor in my GU2, was still working years later when I traded it in.
Graham
Hello everyone, I am new to the forum, also trying to seek answers, the fan switch on my Patrol only worked on 4, I assumed that it was the resistor under the glove box, so at a price of $86 I changed it, only to have it fail after less than 2 hours, could this be indicating another fault of the electrical system somewhere else that I have missed? I don't want to have to spend another $86 only to have it blow again
The fan could be drawing too many amps or you have bought a dud resistor pack. Pull out the pack and check the resistance with a multimeter.
Check there is no rubbish dragging on the fan.
