Did you purchase the vehicle new?
If not, how do you know that the hook has been used only once for a "light" recovery?
Hi Kurt
The problem with buying a hook from Nissan is you are buying it from a salesman who may not know anything about recovering a vehicle in a dangerous situation. If you you are just towing along a dirt road or on the tar it would be fine. We as four wheel drivers put our cars in some situations where recovering the vehicles puts enormous strain on the equipment.
No matter what your club says and I am wondering which member you are getting you advice from, you should always use a aftermarket rated recovery point. Not a tow point. You should only be taking your advice off a properly trained and accredited, driver trainer. It is your life on the line if you get it wrong and you may also cause serious damage to your car.
As for the issue of a rated shackel being a another piece in the recovery system is not a problem as any strap or winch will let go prior to any rated shackel giving way. Also a bow shackel gives a better surface area for a strap to sit into than your hooks. The bow shackel is nice and broad allowing the full face of the strap to pull on whilst a hook only pulls on a portion of the strap face reducing its effectivness.
Regards John
Im with everyone that says scrap the poor excuse of a recovery point that comes factory and get an aftermarket unit. Ive also seen them straighten as a result I was up for a new gu barn door for my mates gu (damn those snatch straps make a nice dint) again this was only a light recovery. Im just thankful that noone was hurt. Just like towballs, poor recovery points can and will kill!
