Yep.. or coppercoat..
https://www.youtube.com/watch?v=Z9_jIa2WADc
Hmm. Theres a cover plate that needs to come off first. Using 3 bolts, i think they are 6mm thread, evenly screw them in and the cover plate comes off. Then you need to remove the centre nut, and theres a circlip in there too from memory. A gear puller is needed now to remove the pulley.
Once the pulley is off you need to press the bearing out. The centre part of the pulley flexes so make sure it stays in the same position when removing and installing the new bearing because if you dont the pulley wont be centred on the pump when you put it back together and the pulley will be out of alignment with the rest of the pulleys.
Close..
But yes that plate has the 3 jacking bolts in it. 3 @ 5mm
Removed the middle bolt first, it holds the nose cone/ cover plate in.
Had them done up to nearly snapping and no go..
So made up the jacking plate to try and budge it but ended up bending the plate. . (3rd bolt is behind middle jacking bolt..)
She is seized on good..
Once plate is off then cir clip and puller to get pullie off...
But never got that far..
1 too many 1900?
>>>tappin from tassie
