NO excuse,thats twice now.....
Very tidy looking bus
Fitted up a tough dog adjustable steering damper
How's the canopy coming along????
Not good need funds for it first
So a few pics of the removing and fitting, learnt a few things and for anyone else you'll need an adjustable spanner or vice grips and 15mm ring spanner preferable of the ratchet variety. My attempts were using a socket which will only allow you to loosen the nut so far as you have to use the adjustable spanner or vice grips to hold the outer edge of the bolt, you will see a flat tapered section on the top end of the bolt.
Attachment 72267
Attachment 72268
Attachment 72269
Attachment 72270
New vs Old Steering Damper
Attachment 72271
Photo of the flush mount RJ45 install, is to connect into the extension lead from the ICOM uhf on a flush mount.
Attachment 72672
Attachment 72673
Also installed an iPad mount will get photos of that later.
So here is the whole setup in the car plus the iPad mount
Attachment 72674
Attachment 72675
Attachment 72676
