Ben I reckon he might have been given either the GQ kit or the pre GU kit. One difference I know of is the upper panhard bush on the later GU one is that big spherical type bush.
Should that make a difference to the overall length and adjustability of the panhard? As far as I'm aware there should be no difference in mounts between Q and U h233's from the centerline of the housing, that's why so many parts are interchangeable. I thought the difference is closer to the hubs or the end of the axle tube, just like the front.
You boys are correct I had a Gq rear panhard and I knew it was wrong because I found the Gu ones on there web site but when I asked about it I was told they are all the same,I thought it that was true then why have they labeled them differently well when I was ordering more parts I told the guy that I had a Gu set up underneath and he said that he was glad that I had told him because some parts are different underneath that is when I asked him about the rear panhard and he told me that I have the wrong one because mine was for a Gq well I knew that from the beginning now I have someone that believe me
