3 Attachment(s)
Nice write up, goes to show some tips never age.
I just started my dual battery install and have nearly exactly the same setup. I bought a cheapie battery holder from Autobahn $30 all up, but had to make an S bracket to bolt on the side of the tray and hold it in place where it tapers off (see 3rd pic even though it's not super clear). For the S bracket I used an old bike training wheel that I cut to size, bent, drilled, painted and bolted into place.
I mounted the Redarc and fuses as seen in the photo's, as I'll be installing a Catch Can in the spot you've got the fuses and Redarc.
I bought the Projecta dual battery monitor and just about to wire it up.
You've given me an idea on where to mount the fuse box as I was scratching my head for best location.
I'm also going to install some USB chargers (not cheap for what they are) and a 300W inverter at the back of the centre console, so kids can charge their devices and laptops.
I found Jaycar has the black flexible plastic tubing 10m for $15 or 10m for $10 for the slightly smaller in diameter.. Cheaper than SuperCheap by about $10.
All up everything included it's set me back $700.
Attachment 61705Attachment 61706Attachment 61707
Nice work, I'm just about to wire mine up and I've picked up some good ideas from this thread.
Funny thing is, the guy at the 4x4 where I bought the Redarc didn't mention anything about installing fuses or circuit breakers between the batteries and the Redarc.
