Would the neutral safety switch be the issue? I've gone from Tb42e auto to td42 manual using the Tb42e auto loom...
What's reds? Have you checked all the fusable links are hooked up & all good, Ignition switch is hooked up right.? Not sure about auto neutral cut out. . Possibly, need someone but more learned than me with electrics but wouldn't stop the accessories from working tho. . .
Can you send a picture of your wiring? And engine bay?
Fusable links..? What's a fusable link?
Where's the ignition switch? Cause i thought that too.. cause the starters not even cranking..
Fusable links come straight off the battery and go to certain parts of the loom. Theres one that goes to the igniting switch (key barrel), sounds like that one might not be hooked up maybe. They're the ones on the left of the battery with white & black plugs.http://www.nissanpatrol.com.au/forum...017/09/187.jpg
I don't have plugs like on mine?
They all sit in a black plastic bracket type thing on the GQs. Kinda hard to see it in pic but next to orange winch wiring. Yours should have something similar . .
Yeh it did I took them all out , but I don't have them wires in the picture? Could you get a closer picture tomorrow?
Hard to get a good picture with all the crap in the way. First ones looking from the back, in the second one should have something that hooks up to the battery like the green & orange plug & black plug. If there not there that'l be your problem i recon. .http://www.nissanpatrol.com.au/forum...017/09/188.jpghttp://www.nissanpatrol.com.au/forum...017/09/189.jpg
