I have had to re-connect the Pre-heat flap as the carby was taking too long to heat up. The next step is to fit a solenoid valve so I can control the flap so there is no chance of it being open when crossing deep water.
I'll leave my pre heat flap alone then, how are you going to control the solenoid activation, a manual switch?
I was thinking of using a manual switch in parallel with a relay powered when the 4wd light comes on, so If I forget it will do automatically shut the flap.
