Quick Question Mr ARB Bossman [emoji120]
My compressor is blown up and I have a flat tyre…..any advice from the…..[emoji23]
Aargh shitbricks, my jackoff doesn’t work either [emoji2957]
Sounds like a typical night in the shed to me.
Wacky thought Philstar, you’ve got an ingenious hydraulic system being built in for F/R Beast winches with Quick Plumbs for auxiliary Farm potential. Why not go the whole way and hydraulic rated ram honestly a Jack to twin-cab GQ tray/bullbar custom mount wherever you like? Suspecting you’d still need a safety prop for each point too in case of fluid blow out/failure and a mechanical jack backup [emoji1696][emoji120]
Placed the order today for the jack, looks a lot safer than the Jackall unit I have used since 1984! Just need to get the base now
Is there any additional wiring Required with the hydraulic jack Philo or as the name suggests purely hydraulic?
Maybe you should just install some outriggers mate? They are hydraulic and don't require 240v [emoji6][emoji6][emoji23]
Every bugger makes a noise at how heavy my barge is, yet encourages me to make it heavier! All good ideas but reckon I will leave that one for a bigger barge than mine Nicco. I think the combo between the airbag, ARB jack and Roadsafe jack extensions I should be right. I bought the entire kit so have a couple of safe options on board.
