I've heard of using chemical compounds but not zero about it, where to buy it, how to use it etc. I will look into this. Thanks.
Hindsight is a wonderful thing mate. We had so much on our minds when builds were going on, a few things were forgotten about unfortunately. Moreso the funds simply ran out for anything extra at the time. I thought about doing as your pic but haven't decided as yet.
Thanks.
Mark, Ramset make a chemical anchor systems (Chemset 101 and 502) and they do supply in spin capsule which would be best option for you. For use of the Ramset cartridge you need their dispenser (costly for small jobs).
Check the video and look for the spin capsules, the 101 type chemical is contained in a class type enclosed tube and the kit also contains threaded studs and nuts. On impact of tube by steel threaded stud the tube shatters and mixes the chemical and cures with stud in situ.
I have used Chemset to secure thread rod in masonary type walls to secure post brackets and the top plate to secure/hold down roof trusses.
https://www.youtube.com/watch?v=q2iKgMKmFiM
Well, build it dear Liza, dear Liza. lol - with all due respect.
I would look at utilising the H posts as well (depending on how they are secured _ in ground with concrete / yes). Maybe use some angle section or similar "profiled up" or off the shelf brkts, so to support the cypress post in the two vertical direction. Structure needs to be stayed /angle braced some how and also to be prevented from pushing out.
Could secure brkt to cypress post with say two thru bolts _ thru the same vertical axis 100mm apart (could use threaded rod or bolts with flanged purlin nuts (look good)
https://www.blackwoods.com.au/fasten...0mm/p/01606956
Purlin bolt are nom 30mm length, it is the nuts I am suggesting here with threaded rod (many options out there).
To attach the rails, bugle batten screw to back of post or angle brkt into side of post and attach rails for infill with wall cladding (only suggestions mate).
If you remove top sleeper as u suggested, will the paver handle that without damage?
Guess you could re bead gap with coloured sikaflex.
I assume this is for some fark tard office pen up his / her ass pen pusher council reg bullshit?
Run Stainless Steel wire from a mount from you house bricks 2 where ever u need 2 end it
OR
Glass fencing
What the width of the concrete sleeper?
