"So the locker can essentially float on the axles in the centre?"
Yeah, you got it, that would be the result if it got any worse.
Sounds like she been like that for a while to do that. Just to be sure take a few measurements to compare with the others before you purchase just to be on the safe side. Other than that i hope it all works out for you.
Cheers Mate,
Appreciate the help.
I have found a 3 litre GU centre on gumtree....
Can anyone tell me if they are the same centers as the 4.2 models??????
As far as i know they are you can bolt centres out of GQs into GUs and vice versa the only thing that changes is the ratio.
edit,
Found one this evening, just whacked the lokka into the center, will install tomorrow.
Thanks all who helped.
