I use Bendix 4wd SUV Hybrid they pull up good
A soft pad will be quiet but make a big mess but a hard compound pad will be noisy but less of a mess. Bendix make great pads and they have a huge range to select from. Repco sell them. If you start with a set of DBA rotors with "Kangaroo paw" internal pattern are great. You can buy cross drilled or slotted. Had these on a race car and they worked a treat. They will disperse heat quickly and are as strong as. If you have 4 spot calipers even better. A soft pad will be quiet but make a big mess but a hard compound pad will be noisy but less of a mess. Bendix make great pads and they have a huge range to select from. Repco sell them.
Bendix for me as well. Got the HD ones and flushed the fluid. Pulls up well.
I have RDA dimpled/grooved rotors plus EBC Greenstuff 6000 series pads. Definite improvement over stock & I’d buy them again.
Did anyone else see this in the current supercheap catalogue? Does it extend to their 4wd pads as well?
http://www.nissanpatrol.com.au/forum...015/09/377.jpg
I have also been using Bendix for many years.
"Bacho" I seen that catalogue and checked today at my local SC. I was told that the special was only for in store stock.
They had the Bendix for the front in store but don't keep the Bendix rears, so the deal does not apply.
Interested to know if any of their stores keep front and rears.
:cheers:
Did you go with the set up in the link??
A few here run ADR braided hoses with great pedal feel
Not too pricey $$ well for my model.
http://www.nissanpatrol.com.au/forum...formance-Lines
Is it a big job fitting the braided hoses, its beyond me atm as I cant get under the patrol,
Do you need one of those 4 in 1 bleeder hoses??
