Thats really odd to me, i have found that 2nd low was best for me, to much wheel spin in 1st, and have done a lot of wheeling like that. I do agree with 1st low going down hill being a hassle.
My car is a 4.5 auto on gas as well
You really should keep your foot well away from the clutch when ascending a steep hill. My low 1st will climb almost anything but have been considering reduction gears for a while, mainly for super slow and controlled decents. Think I'm going to change the diff centres first though.
The 65%ers sound like like they're the business.
Went out with my 63% reduction gears today and found them to be fantastic. Going up hill I now have more than enough for almost anything that I will encounter, and down hill is such a massive improvement. some of the steepest stuff I did today I didn't need to touch the break at all, going down in full control with the reves around 1500- 2000, very happy with my investment. I would still love to see a set 85s in action to see how much of a step up they would be. I would think they would be far too low for the kind of stuff I do, heading into competition territory I reckon. The 43s wouldn't be worth looking at I feel.
Awesome, thanks for the update!
So stuff for which 1 low was previously alright, would you use 2 low for that now?
Did it take long to get used to?
Yeah, I have only been out once so more runs are needed but I would say 2nd low now is what 1st use to be may be even a little lower, I will know more when I get back to the high country and tackle some of those tracks that I have had experience on. as to getting use to them well the more you do the better you will know but having the revs in the right range for whatever speed and the gear you are in is a feel you have for your own car. I mean you can tell if your car is labouring or in that sweet spot without knowing what gear you are in, adjusting as you go.
Back for another update on my gears. Just got back from the High Country and I got to say that the 63% reduction gears that I have fitted are easily the best mod that I have done and possibly ever could do being an auto. Going down steep grades without touching the break, beautiful. Going uphill in drive and the trans chooses 3rd gear, amazing. Low enough for safe hill descent and high enough not to be constantly changing from high to low. Very Very happy.
What are your thoughts on these 63% fitted to a 3ltr TD auto.
Next on my list is a Pro-Locker for the front.
They sound like a great investment. The Patrols only come with 2:1 reduction as standard which is not very low. A lot of other makes come with around 2.5:1 reduction gears which helps them a lot. My 3.0 ltr TD is a manual and I find that I sometimes have to scrub some speed off using the brake on steep descents or that the motor lugs in 1st low up steep inclines when traveling slow for control.
From memory they do 45%, 63% and 85% reduction gears? Looks like picking the middle option gives you around 2.6:1 reduction which is the most versatile.
EDIT: Just looked up Marks adapters and reduction ratios are as follows:
24% ---------- 2.484:1
43% ---------- 2.86:1
85% ---------- 3.743:1
Where did you get the 63% reduction ratios Chubba? Are the a Marks adapter item or is someone else making them?
Well threedogs I don't know if you followed the group buy thread that was on here but I bought two sets, one for me and one for my brother. He had a 4.5L petrol auto at the time but as things worked out he was rear ended in the petrol before he had a chance to install the gears. it was a wright off and he ended up getting a 3l TD auto. He was on the trip with me and he is just as pleased as me. My thoughts are "DO IT"
Rocktrol, They are from Marsk's and they don't normally do the 63s but a fella on here organized a group buy, he needed 20 orders min, I think he ended up with about 25 and Marks made them. Here's the link http://www.nissanpatrol.com.au/forum...tion-for-GQ-GU
