Did you beef up the auto while it was being rebuilt?
john. Hi , i put a few extra frictions in where i could and some new bushes and band and solenoid set and filter and gasket and seal kit.Only modified the valve body to give it extra lube pressure. don't want it to shift any harder than it did already. also removed the lube relief valve in back of case. converter was reco to standard specs. Oh and a coat of paint .
Well I have been busy.This is not something I would ever do again. Glad I had a whole car to get what I wanted.All the little things like starter and earth cables slightly thicker on the diesel,brackets and clips that were on the diesel but not on the petrol and so on.Its all up and running and has done about 800 k's.Runs like a clock. Here are some pics I took along the journey.Attachment 61603This is the time to start dismantling my patrol.
When I bought this new 26 years ago I never thought I would be doing this to it.Attachment 61604Attachment 61605Attachment 61606
Onwards and upwardsAttachment 61607Attachment 61608Attachment 61609Got a couple of wires to hook up and my diesel lines and tank
I lost my diesel acc cable in the process. I think I put it somewhere really safe. One day I'll find it. For now I had to buy a new one.Attachment 61610
My new 3 inch exhaust from Beaudesert Exhausts.Attachment 61611
My new motor ready to slip in it's new home
Attachment 61612
I was going to use my transfer case off my manual box behind the auto but it didn't have the park /neutral switch which warns you if you put the auto in park but the transfer box is in neutral. no biggy but if something ever happened I guess I would be responsible so I used the one off the auto.
That was never there beforeAttachment 61613Attachment 61614Attachment 61615
Time to slip it inAttachment 61616 Looks like it was made for it . Well ok it was, but still looks good.Attachment 61617Attachment 61618 Time to squeeze in the auto cooler and condenser fan. Had to modify the grille a bit to get it to fit, and a new set of grille clips to hold it in place.Attachment 61619
Now it's time to put the dash back in.Attachment 61620Attachment 61657Attachment 61658Attachment 61659Attachment 61660Attachment 61661
Well it's coming together nicely .Attachment 61621Attachment 61622
I have to fit a snorkel now so time to cut a hole in the guard.It's taken me 26 years to work up the courage to cut a dirty great hole in the guard but here goes.Attachment 61624.Now for the snorkel.Attachment 61623Attachment 61625
