How do you disconnect the annoying ignition key alarm in a 2012?
When the motor is off but the keys are in the ignition and when the door is open the annoying alarm just won't shut up.
Hope this helps.
http://www.nissanpatrol.com.au/forum...id=65811&stc=1
Thanks heaps.
It drives me nuts and the pasangers.
Bliss, all done.
Thanks again
Thank you !
Me to thank you
Finally got the shites with the 'key in ignition' alarm so tried the 'easy fix'. Thought I should get some help but seemed easy and what could go wrong...
So ended up with fine copper wire and bits of plastic all over the place ! Tried to glue / solder etc but no dice. Looks like a new IMMU thingy is needed. Any ideas to the best place to get one fast ?
How do you disconnect the ignition key alarm, in a 2012 GU8?
