Hey all I am helping a bloke build Aluminium Tray Trailers & the other day I looked at 1 of the drop sides & thought a set of roller bearings would run pretty good in this.
Next I thought well I could do with a set of rear draws in the ol' GQ so I thought I'd post here as I go this is all just using the offcuts from the bigger 4.2mtr x 2.0mtr trailers we are currently building.
Heres some quick pics from todays start on draw setup.
The sides are 940 long by 300mm high after putting my 50ltr waeco on top I'll have bout 25mm spare height to get it out rear door of GQ then it will tilt so I can access hole fridge but thats later on.
nice drawers hammerbuilder. how did you attach the fridge slide? cheers,
more pics cross bars out of U section left side is 450mm wide draw gap right side is 550mm wide n all tig together 300mm high
next step is to bend the top n back end cover & also to bend the draw trays themselves.
This is excellent HammerBuilder . I was thinking of doing something similar soon hopefully . Can't wait to see the finished unit .
