GU 2004 ZD30 ST Rear AC install
Hi Guys,
I have a 2004 ZD30 ST that I'm barra converting.
One thing that is a must is the installation of the rear Aircon for the rear passengers.
So I pulled the complete kit out of a 2012 ST yesterday and came to the realisation that the harness fitted currently to my car maybe doesn't have the provision for the aircon controls under the centre console. Has anyone previously done this conversion and could spread some light/knowledge?
I found the wiring for the rear evaporator unit was all there, and I do have the looms from the 2012 model that runs from the multi connector right through to the taillights on both sides of the car, and links through underneath the front seats and Centre console, but I have no access to the manuals to confirm if this harness is compatible with my model (IE plug and play without affecting anything else)
What I pulled from the 2012 is as follows:
- Both harnesses inside cab from under CC through to tail lights
- Centre Console with rear fan control
- Rear A/C switch from dash
- Rear A/C unit, all ducting, roofliners etc
- Rear quarter panel card and window surround for both sides
- A/C hoses from engine bay to a/c evaporator
I have seen mention that the rear window on passenger side is infact different? can anyone also comment on that?
Cheers,
Scott
