Nissan Patrol 1990 TB42 - 4.2 Lt Petrol - Idling Issues
Having a lot of problems with a friends car. Idling to high and stalling if below 1000rpm.
Compression test was good over all cylinders. Around 175psi. No more than 10psi difference over all cylinders
New Spark Plugs.
Leads tested ok
Replaced Carby with aftermarket carby. No difference from old carby
New fuel filter.
Had to set rpm to 1800 so that when I dropped it would not stall when stopping. Rpm sometimes sits at 1100 other times up to 1800. Runs rough sometimes.
Replaced points in distributor Bingo perfect start idling St around 700 to 750. 1hr later had to adjust carby back up to 1800rms as it continued to stall.
Timing was at 20 degrees. Set back to 10 as per specifications.
Set points gap at 0.5mm. Specifications suggest 0.45 to 0 55.
No visible leak from intake manifold gasket or manifold
Set choke. No more black smoke.
Out of ideas.
Has anyone been able to overcome this idling issue?
