Anyone got tips on how to or is it easy to change rear rotors and pads???? Thx workshop manual would be good?..
Easy. Pull wheels off, remove calipers, rear rotors then just slide off (may need a little persuasion), change the pads and reassemble.
Thanks mate I'll see how I go
Cant remember for sure but if there's a threaded hole or two on the rotor, find a spare bolt and use this to pry the disc off if its tight
there is a few other things you need to do
eg take out 1/2 break fluid
calipers need to be spread open so as to get the new pads in
go to youtube and watch someone doing it
and it gives you a better knowledge on how to do the job
here is a link
https://www.youtube.com/watch?v=gE59rKXEoos
Just finished changing them was really easy and they are great
Had to change the fuel filter and finally found where it was that was easy to change as we'll
I need to change the fan belts and all that will be next weekends job ... Then put my rooftop tent on and I'll be ready for some people to come 4wding with me :)
Good to hear you finished OK, fronts are a bit trickier..
Where's Tannum???
Qld near Gladstone
