3 Attachment(s)
What are those metal tubes running up the side of the ZD30 auto trans?
There are 2 metal tubes that come down the passenger side chassis rail from the engine bay; then cross UNDER the exhaust via plastic tubing; then go up the passenger side of the auto trans as metal tubes.
Pls see attached image.
What is the function/purpose of these tubes?
As may be seen, the 2 tubes are 'open' - and may have been for some time. :(
I can reconnect one rubber tube to a metal tube easily enough. In this case, the black plastic contains a bit of broken-off metal tube. Secure with hose clamps.
[Simple reconnection is probably better than unconnected! :)]
Then I need to get another plastic connector and connect up the other run.
Likely to be a lot of coal dust up those tubes - given how long this vehicle work at a coal mine...
What should I do first? Flush with soapy water?? Blow out with compressed air? Both?
Note the difficulty accessing the other end of the tubes above the trans.
The ends in the engine bay disappear into a caving in the front guard - behind the radiator coolant overflow tank.
For advice pls.
