Hey guys have not been on in a while so hi
I have 2inch lift currently and found some 30mm spacer in the shed I want use. What do you guys think ill need. Obvious things are brake line and sway bar links anything else?
still only going to have 2" suspension
I don't like spacers, in my opinion its creating a weak link in the system. But if you want it go for it. Brake lines maybe needed to do them for 4" and swaybar most likely
That will end up a touch over a 3 inch lift. So everything you need for a 3 inch lift you will need
