Live alternator wire for delivery pump
Hi everyone.
I've fitted a diesel delivery pump down beside the rear fuel tank of my Y61 TD42ti and wired it up using a relay. It's all finished bar locating a live feed wire from the alternator. For safety reasons, I want the relay to lose its feed when the alternator stops spinning and hence kill power to the pump. Can anyone clearly tell me where I could find the required wire to tap into? The relay is attached to one of the wiper motor bolts so ideally I would like a wire that is in the fuse box area but if it has to come all the way from the the alternator then so be it. I've also been told that I will need to fit an in-line diode regardless of where I get the feed from. Is this true? I hope I've explained what I'm trying to do well enough. Any help would be greatly appreciated. Thanks, Deevo.
